Sunroof removal instructions?
I'm a new S80 owner... I need to know how to remove the sunroof glass in order to get access to the sliding cover beneath it. I need to replace a broken rail guide on the cover and it looks like removing the glass is the best way to get to the guide.Any ideas?
PK ________ Lincoln town car specifications |
RE: Sunroof removal instructions?
Tilt the glass up.
Then slide the little black panels away from the glass then you will see the screws to remove them. |
I see the pair of torx screws on the L & R side of the glass. I don't know howtoaccess the screw heads with a regular set oftorx "screw driver handled" tools. Is a special shaped driver required or is there another way?
________ ROLLING A JOINT |
As Tech said, it is straightforward. No special tools are needed.
To see the VADIS instructions: http://www.matthewsvolvosite.com/cha...hlight=sunroof |
