Sunroof removal instructions?
Old Mar 29, 2008 | 10:41 PM
PieceKeeper's Avatar
Default Sunroof removal instructions?
I'm a new S80 owner... I need to know how to remove the sunroof glass in order to get access to the sliding cover beneath it. I need to replace a broken rail guide on the cover and it looks like removing the glass is the best way to get to the guide.Any ideas?
PK
________
Lincoln town car specifications
Old Mar 30, 2008 | 09:19 AM
Default RE: Sunroof removal instructions?
Tilt the glass up.
Then slide the little black panels away from the glass then you will see the screws to remove them.
Old Mar 30, 2008 | 04:05 PM
I see the pair of torx screws on the L & R side of the glass. I don't know howtoaccess the screw heads with a regular set oftorx "screw driver handled" tools. Is a special shaped driver required or is there another way?
________
ROLLING A JOINT
Old Mar 30, 2008 | 04:19 PM
billofdurham's Avatar
As Tech said, it is straightforward. No special tools are needed.
To see the VADIS instructions:
http://www.matthewsvolvosite.com/cha...hlight=sunroof
jclark5093
May 31, 2011 10:19 AM
tactic
Jul 9, 2010 09:34 PM
surfaccing
Mar 27, 2010 07:09 PM
Mars
May 21, 2007 04:21 AM
TheVolvoMan
Dec 6, 2004 01:42 AM
