sunroof stopped working
All the sudden my power sunroof won't work. Right now the back is opened to vent and I can't get it back down. I also noticed the 2 of the lights will not come on in the same module the sunroof switch is housed in. I checked the fuses but they look good. There's a total of 4 lights in the module the 2 which come on when you open the door are working, however the 2 map lights which are switched will not come on when you hit the switch
Any thoughts?
Any thoughts?
RE: sunroof stopped working
I occasionally have the similar problem. The fuse isn't the issue in my car either. Often times enough, I can just switch off my car and turn it back on a time or two, or three...and it will work again. My guess is one of the relays is faulty, but I don't have the time to really investigate. If you can get a map of the relays and find out which one it is, try replacing it.
ORIGINAL: familyman
Any thoughts?
Any thoughts?
this just happend to me, see here
https://volvoforums.com/m_27423/tm.htm
but if you don't feel like reading, all you should need to do is lock and unlock your doors with your key.
DaveDog2010
05-17-2021 09:00 AM
