Sunroof stopped responding
Old May 11, 2008 | 10:12 PM
jessebkaye's Avatar
Default Sunroof stopped responding
So this afternoon I got into my S60 and tried to open the sunroof and NOTHING HAPPENED. Its wierd because I had it openend this morning and it shut just fine. now its as if the fuse is bad but its not. when I use the switch I hear no noise either, should I expect to hear the click of a relay? If its the motor I thought I would hear the relay 'click' but I dont. Maybe a bad switch? Maybe an electrical connection?
Any advice is greatly appreciated.
Old May 12, 2008 | 05:40 PM
Default RE: Sunroof stopped responding
Did you get an alarm system service message lately?
Was the battery dead lately?
Old May 12, 2008 | 08:25 PM
jessebkaye's Avatar
Yes, oddly enough I did get the alarm service message about a day before the sunroof stopped responding. How do the two relate? My post after this one was regarding the alarm service message.
Old May 12, 2008 | 09:28 PM
Scott6's Avatar
Various normal things stoped working about 1 week before my altanator died. The sunroof. the windows, all dor lock except the driver side. Raido, trunk
Old May 16, 2008 | 05:55 PM
volvotechky's Avatar
You need to reinitialize the UEM, put the Key in the drivers door, turn it to lock then unlock twice. if you cant get it done pull into the dealers service drive, ask a guy to renitialize the UEM for ya, they'll do it for free. takes like 5secs..
Old May 24, 2008 | 04:23 PM
mncx's Avatar
If alarm siren is bad can cause the sunroof module to stop working because they are all in the same network. By re-initializing CAN network is just a temporarily fix as I've seen in the past the best thing is to fault trace the network circuitfor the Sunroof and alarm siren.
Old May 24, 2008 | 09:27 PM
kinda hard to diaginose a can system w/out vida and when you dont know the system. The best way to tell if the Alarm siren is or isnt working. is to push to alarm button on the remote. If it sounds it is working properly
Old May 25, 2008 | 12:40 AM
mncx's Avatar
ORIGINAL: volvotechky
In that system all u can check is the wiring... no need vida... if all wiring good unplug siren and see if the sunroof come back to life.. at time can set DTC for sirenbut a lot of time will not.. It's serial network on siren, sunroof and mass movement (if applicable) the serial network is slave to UEM in which is on CAN... This fault tracing is very similar to the one for new S40/V50 LIN network (unplug till it comes back to life)
JadysV
Volvo C30
Jan 31, 2022 12:47 PM
Wildfirexxl
Apr 9, 2014 03:12 PM
SIMAUD
Jun 13, 2009 02:53 PM
chef
May 5, 2009 06:38 PM
ahmetg
Jan 7, 2007 02:51 AM
