Tranny problems
Old Nov 3, 2006 | 11:38 PM
oaeyeo121003's Avatar
Default Tranny problems
does the s80 t6 have a seperate tranny controller from the ecu?
Old Nov 3, 2006 | 11:51 PM
poopbunny's Avatar
Default RE: Tranny problems
Yes. Called TCM
Old Nov 4, 2006 | 01:05 AM
Ihatespeedbumps's Avatar
ORIGINAL: poopbunny
Yes. Called TCM
yep.
Old Nov 4, 2006 | 01:29 AM
You are going to have to be Very careful and Plan really good on the project you are making.
The S80 is a networked car. The cars have between 12 and 20 computers in the Network depending on the options the car comes with.
The module will have to be programed. Which it might not be able to have done and it might not run/drive right.
Not sure if the 960 computer will drive the trans matched up with the S80 TT engine.
I would install the turbo setup and try to use a stand alone fuel managment system and see what happens from there.
Old Nov 4, 2006 | 01:43 AM
I have acess to a baum which will fix the programming, as of obd2 every car is suppossed to have a pcm and not seperate controllers, however lots of them do, the question is if the v90 trans bolts up and is seperate then
Old Nov 4, 2006 | 10:59 AM
It might bolt up but never tried.
They are pretty much the exact same block with minor differences.
Block91
2001-2013 model year V70
23
Apr 3, 2020 09:53 PM
dooda28
Aug 23, 2007 09:26 PM
gooproduct
Jul 20, 2007 10:00 AM
hanifrez
Jan 15, 2007 09:02 PM
etrium
Nov 24, 2006 10:12 AM
