'95 850 tranny issues--shifting problems
Old Jul 17, 2007 | 07:32 PM
gooproduct's Avatar
Default '95 850 tranny issues--shifting problems
When my '95 850 turbo wagon has been running awhile and the engine is hot, after I come to a complete stop and then accelerate, it acts as if it is in third or fourth gear. The engine revs, but I don't speed up until I hit the throttle hard enough. Then, it shifts into the proper gear. It will be fine for the rest of the day.
Any help is appreciated.
Old Jul 18, 2007 | 01:54 AM
JPN's Avatar
JPN
Default RE: '95 850 tranny issues--shifting problems
Hi,
Sorry about the problem.
Is the "Arrow" on the instrument panel flashing? I assume not, as you did not mention of it.
I would check the transmission fluid level & condition. The fluid should be clear red and should not have burnt smell or discolouration. If you find either, it's time to flush the transmission.
These threads may help:
https://volvoforums.com/m_65687/tm.htm
https://volvoforums.com/m_48928/tm.htm
Also, try retrieving codes from the transmission ECU:
http://volvospeed.com/Repair/a1.html
I hope this gets you started.
JPN
Old Jul 20, 2007 | 07:22 AM
gooproduct's Avatar
So sorry it has taken a while toget back on here. Thank you for the advice, I'll check the fluid and most likely have it flushed anyway then go from there. I do have a ODBII reader so I'll check the tranny codes too. Thanks again and I'll post any new data.
Old Jul 20, 2007 | 10:00 AM
JPN's Avatar
JPN
Hello Good product,
There's nothing to be sorry about, but thanks.
Shifting problem is not only inconvenient but is also dangerous, so I hope the problem gets resolved asap. In case if the transmission goes out of control while you're driving, just hit the shifter into "N"; you do not need to press the shifter button between "D" and "N".
I wish you the best,
JPN
dtbaker61
Engine & Internal
Jan 1, 2014 11:40 AM
netweaver
Aug 1, 2010 05:41 PM
doovie
Feb 23, 2009 05:04 PM
my850turbo
Dec 19, 2005 09:19 PM
GaryBrad
Aug 12, 2005 10:21 PM
