Vaccum leak S80 T6 1999 HELP me please
Old Nov 12, 2010 | 01:50 AM
shane.hatlee's Avatar
Default Vaccum leak S80 T6 1999 HELP me please
I know i have to replace my brake booster it has a bad seal and every now and then it hisses alot of air and simple touch of my pedal will normally seal it back up. but i fear there is another leak and i cant find it. I cleaned my throttle body, had the head gasket replaced my head machined, new plugs fresh penzoil platinum, new O2 sensor bank 2 sensor 1, new air filter, new radiator, heater core..... long list. and spark plugs.
I have a lack of power at times, Can hear a sucking on the passenger side with the glovee box off but im always driving. the car feels as though there is a very very suble skip, it runs a little rough and i can see the dash lights very very subtly flicker bright then low. My alternator is good and this has ocured since i got the car. Im wondering if anyone can tell me where all the vaccum lines this car has are. i will replace tehm all good or not if they are cheap enough. i want this car to drive as it sould. Please any help would be appreciated
Old Nov 12, 2010 | 11:20 AM
NoLifeTilBoost's Avatar
If the alternator is good (you are getting 14v at idle?) the this could be either battery or ETM depending on how rough it is exactly...
There is a vacuum (well pressure) tube that goes to the wastegate actuators for each turbo. It could be that pipe for turbo 1 on the passenger side thats leaking. If you follow the three pipes from your TCV solenoid (should be clipped onto your air filter box), one goes to the plastic pipe on top of the engine, one goes to the inlet plastic pipe and a third goes towards the rear to a metal pipe near where the tranny dipstick is. Follow this metal pipe as it splits to the two turbos. At that point you will see a 2-3" piece of silicone hose connecting the metal pipe to the wastegate actuators on the turbos. If these pipes are leaking it would explain poor running for sure.
Old Nov 13, 2010 | 10:27 AM
mikebrooks's Avatar
By wastegate do you mean for air or is this for oil?
Old Nov 14, 2010 | 07:22 AM
The wategates are actuated by Air.
The oil pipes for the turbos live exclusively at the exhaust side of the engine.
Old Sep 16, 2011 | 07:29 PM
1997VolvoFazio's Avatar
Hi I have a 1997 Volvo 960 with the same problems. I have Drawings that i can send you by Fax. I dont think its a vaccum line but it my be a vaccum diagham. I went to the Volvo parts dept and they gave me the drawing. My email is Georgefazio@yahoo.com or cell 516-860-7316. Please let me know I am going to get under my dash tomorrow. If I find anyrhing I will forward.
Old Sep 16, 2011 | 10:51 PM
poopbunny's Avatar
The air hose with the yellow band and connected to the outlet of the TCV marked yellow is the wastegate. You may need to wipe the hose or the TCV a little as soot could accumulate over the years obscuring it.
I replaced all my TCV hoses just last week on a 1999 T6 just out of curiosity that many others have also done it and the resultant notable improvements. I just used the cheaper IPD blue silicone hoses, maybe only a few $ (OES ones are about $50) and it did make a difference althought I did not detect any leaks. The hoses however were very brittle and I had to cut into some as they did not pull easily even with the hose clips removed.
jorgeaiello
Oct 11, 2010 10:23 AM
dkvcopy
Sep 13, 2010 05:10 AM
thekoopa
Sep 2, 2009 06:26 PM
S70driver
Aug 30, 2007 11:08 AM
dcox612
Apr 23, 2006 01:47 PM
