Valve noise?
Old Jan 16, 2007 | 07:53 PM
go2sharks's Avatar
Default Valve noise?
My 2000 S80 2.9L non-turbo, 45K miles.
Seems to have valve noise. Aren't these self adjusting valve controls or something like that? Another word, do I need to do manual valve adjustment? OR thenoise could be something else?
Ok, I'll stop posting. Too much free time today.
Old Jan 16, 2007 | 11:18 PM
Default RE: Valve noise?
Some have hydrolic lifters and some have solid lifters.
Once you take the black top cover off look and see if you have 4 Torxes screws around each cylinder. They screw into the Cam Cover.
If you have the screws then they are solid lifters.
If not hydrolic lifters.
Solid lifters will cost about $1000.00 to get adjusted.(maybe a little less but takes about 5 to 6 hours to adjust.
Old Jan 17, 2007 | 03:06 PM
akirk6884's Avatar
I went and test drove both a brand new 06 s60 and a 07 s80 3.2. The sounds your hearing are probably what I was wondering myself on my 02 s80 t6, nonetheless my engine sounds identical to a brand new volvo engine. So I would guess hydraulic lifters, also the Variable Valve Timing is going to be noiser. Just my thoughts...
Old Jan 17, 2007 | 09:04 PM
On the New cars the Injectors are very loud.
Old Jan 17, 2007 | 09:55 PM
go2sharks's Avatar
Aftering reading more post, I think there are mention about oil O rings set replacement.Well, when I do my tune up, I'll look to see if it's manual lifter or not. If hydrolic then O-rings set. If manual, then valve adjustment is needed.
With that said, my car only has 45K mile, not only that, I noticed this loud engine noise a long time ago. Oh, we'll see. I'll report back.
Old Jan 17, 2007 | 11:43 PM
I will bet oil pan o-rings.
peace562
Feb 20, 2015 07:39 PM
rhayles
Oct 24, 2012 11:02 AM
Rakam
May 27, 2011 09:03 PM
chachouu
Apr 8, 2010 03:51 PM
mygreenbomb
Feb 29, 2008 06:09 PM
