-   Volvo S80 (https://volvoforums.com/forum/volvo-s80-18/)
-   -   Volvo S80 1999 Transmission (https://volvoforums.com/forum/volvo-s80-18/volvo-s80-1999-transmission-64695/)
majorcode Aug 3, 2012 02:47 AM
Hi,
My Volvo s80 1999 with 145K KM is finally done with the used Transmission which works fine.
My Q is since these models are prone to have transmission problems, how I can keep this car with me longer and keep transmission healthy?
Last Problem: Since Volvo says there Transmission oil is for life time (Can be good in Euro/Us) but in Middle east some times we have over 60C heat therefore I lost my transmission because its transmission oil was never changed....which destroyed my Transmission's clutch plates, valve body, solenoids etc.
PieceKeeper Aug 4, 2012 11:06 PM
Change the fluid! Even the owner's manual says to do so. It's easy on these cars because they have a drain plug (you don't have to drop the entire pan). Drain and fill, stay away from the power flush because more times than not, it tends to stir up debris.
I'm out in the Phoenix, AZ area. We don't see 60°C out here (45-50 is more common). But, I'm running 178k miles on the original tranny. Take care of it and with a little luck, you'll be okay.
majorcode Aug 6, 2012 07:49 AM
PieceKeeper, No, so far I know 1999 s80 2.9 does not have any drain plug and therefore in order to change the oil we must drop the pan.
Please share if you any authenticated information, whether this model has drain plug or not.
meronleaon Aug 24, 2012 12:52 PM
Volvo previously declared that its new leading 'Executive' design, so far the most more luxuriously outfitted item, has been included to the all-new Volvo S80 saloon variety.
