Volvo S80 1999 Transmission
Old Aug 3, 2012 | 02:47 AM
majorcode's Avatar
Default Volvo S80 1999 Transmission
Hi,
My Volvo s80 1999 with 145K KM is finally done with the used Transmission which works fine.
My Q is since these models are prone to have transmission problems, how I can keep this car with me longer and keep transmission healthy?
Last Problem: Since Volvo says there Transmission oil is for life time (Can be good in Euro/Us) but in Middle east some times we have over 60C heat therefore I lost my transmission because its transmission oil was never changed....which destroyed my Transmission's clutch plates, valve body, solenoids etc.
Old Aug 4, 2012 | 11:06 PM
PieceKeeper's Avatar
Change the fluid! Even the owner's manual says to do so. It's easy on these cars because they have a drain plug (you don't have to drop the entire pan). Drain and fill, stay away from the power flush because more times than not, it tends to stir up debris.
I'm out in the Phoenix, AZ area. We don't see 60°C out here (45-50 is more common). But, I'm running 178k miles on the original tranny. Take care of it and with a little luck, you'll be okay.
Old Aug 6, 2012 | 07:49 AM
majorcode's Avatar
PieceKeeper, No, so far I know 1999 s80 2.9 does not have any drain plug and therefore in order to change the oil we must drop the pan.
Please share if you any authenticated information, whether this model has drain plug or not.
Old Aug 24, 2012 | 12:52 PM
meronleaon's Avatar
Volvo previously declared that its new leading 'Executive' design, so far the most more luxuriously outfitted item, has been included to the all-new Volvo S80 saloon variety.
darkostoj
Aug 1, 2018 08:27 AM
koziolek
Sep 19, 2016 03:26 PM
kpmp64
May 6, 2012 05:19 PM
7antera
Jun 2, 2008 08:00 AM
gratefulvolvo
Dec 9, 2007 04:30 PM
