washer fluid bottle
this is what i found. altho its for washer motor but the steps to access is still the same
Washer Motor
-Before servicing the vehicle, refer to the precautions.
-Remove the filter cover on the control module box
-Remove the filler pipe.
-Separate the hoses at the filler pipe.
-Remove the front bumper and casing.
https://i.imgur.com/01zkd.gif
-Disconnect the connector under the reservoir
-Remove the screws from the reservoir
-Carefully tension out the soft nose. Release and pull out the reservoir slightly
-Remove the air intake pipe for the control module box from the mounting on the reservoir
-Take down the reservoir.
-Angle the windshield washer reservoir so that the windshield washer fluid does not leak. -Alternatively empty the reservoir.
-Remove the hose from the motor
-Disconnect the connector from the motor
-Remove the motor from the reservoir.
https://i.imgur.com/2uRNX.gif
To install:
-Installation is the reverse of removal.
NOTE
-Before installing the pump, immerse the inlet pipe in water or a soap solution to avoid compressing the rubber seal.
Washer Motor
To install:
NOTE
