What's the Procedure of Starting an engine S80 2001 2.0T !!!
Hello Guys,
M driving a S80 2001 2.0T engine B5204T5 series...m sorry to be asking this silly question & hope u guys will teach me the correct method or procedure for STARTING AN ENGINE. 1) I put the key into the ignition slot & turn it to position II...all the red lights on the dashboard on the right hand side will do a check(example : airbag, check engine, service, ABS, parking....) while there will be also a chime sound that will ring for 5 times.....ting ting ting ting ting....then only i start the engine(Position III & release it)......after starting the engine it will do another check on the red lights like ABS, check engine....)... during that time the chime sound will ring 5 times...ting ting ting ting ting. Once this is done...i buckle up my seat belt & start driving. 2) I put the key into the ignition slot & turn to position II...I start the engine straight away(Position III & release it) while the systems checks the ABS, check engine..... at the same time also the chimes rings 5 times...ting ting ting ting ting. Once this is done...i buckle up my seat belt & start driving. So guys, pls educate me...what's the proper procedure for STARTING AN ENGINE for S80 2001 2.0T...is it number 1 or number 2 of the above mentioned ? |
RE: What's the Procedure of Starting an engine S80 2001 2.0T !!!
Hey guys,
Need your opinion & advice...so...is it number 1 or number 2. All replies would be gladly appreciated in advance |
2. Is fine.
I always just get in and turn and start and go!! |
ORIGINAL: tech 2. Is fine. I always just get in and turn and start and go!! |
