Whistle noise at idle
Old Dec 6, 2022 | 08:06 PM
Lzheng2's Avatar
Default Whistle noise at idle
Hi, I have a 2012 s80 t6. It makes a whistle noise at idle. The noise disappears right after I press the gas even gently. So I hear clearly it comes and go. Only hear it after car warms up. No check engine light. No rough idle (600rpm at idle). I just replaced pcv and vacuum pump seals. Nothing changes. I appreciate your comments!
Old Dec 12, 2022 | 06:18 AM
dh2of3's Avatar
I have a 2008 S80 3.2, experienced a whistle too. Try this... At idle, with whistle present, pull the oil dipstick out a few inches. Does whistle stop? If so, it is the oil breather box mounted on the top and rear of the engine near firewall. A flap (?) Inside it wears out. Cost me 500$ US 5 to 7 years ago at a dealer to replace and have installed. The part is bolted/screwed into engine with 8 easy to get to screws. There is no mess, might be an electric connection too. Now I know that I could change it out myself. I was traveling and had no tools. Hope this helps.
Old Dec 12, 2022 | 08:08 AM
Lzheng2's Avatar
Thank you for comment. It does not stop when pulling the oil dipstick. Nevertheless I go ahead to change pcv on the breath box since it is only $20. A whole breath box costs $200. The diaphragm looks good unfortunately. My next guess is a worn pulley. Alternator decoupled pulley?
Old Dec 12, 2022 | 04:58 PM
dh2of3's Avatar
I get my pulleys replaced when I replace the belt around every 125,000 miles, so Ive never had any pulley issues. Best of luck with your solution.
Old Mar 2, 2023 | 01:02 PM
Lzheng2's Avatar
Default Update
Just update in case others are interested in. Since the car has a high mileage, I just replaced belt, idler pulley, tensioner, water pump, and alternator decoupling pulley. Since I replaced the water pump, I also changed coolant. The noice is Gone! Now very smooth. The total cost is about $200. It took me four hours.
Old Mar 3, 2023 | 08:11 AM
PeterMetaxas's Avatar
Your own labour obviously. $200 is parts only. Seems very inexpensive.
Old Mar 3, 2023 | 09:18 AM
Lzheng2's Avatar
that’s correct. Very happy at the end.
Roland Gaasbakl
Mar 6, 2021 01:24 PM
Lanabanana
Jul 6, 2013 10:22 PM
BoomeR
Sep 6, 2009 03:32 PM
oldfooter
Jan 13, 2009 05:19 PM
cazman
Sep 13, 2005 09:27 PM
