1998 V90 Engine Interference
Old Jan 24, 2025 | 10:41 AM
SmthBlue's Avatar
Default 1998 V90 Engine Interference
I've got a listing for a 1998 V90 Wagon with a broken timing belt and I was wondering if the engine in that model was interference or not. I want to know what I'd be getting myself into before going to check it out.
Old Jan 24, 2025 | 02:48 PM
Yes that engine will have 24 bent valves. (it's the same as all the other "white block" 4 and 5 cylinder engines) And will cost way more (retail) to fix than the car is worth. Even if you are doing all the labor by your self - you will spend more than the car is worth fixing it.
Old Feb 7, 2026 | 06:26 AM
sallyromme12's Avatar
Hasn’t the timing belt been changed? It should’ve been if serviced with Volvo. Check under the bonnet for a square grey sticker with a picture of a timing belt on it.
mabvt3@gmail.com
Sep 30, 2022 02:10 PM
bwboland
Jun 27, 2015 07:15 PM
martin calva
Apr 20, 2015 03:01 AM
jfisher
Mar 3, 2010 09:01 PM
