Check Engine Diagnostics Help
Old Dec 12, 2010 | 03:31 PM
getagrp1k's Avatar
Exclamation Check Engine Diagnostics Help
I have a 2005 XC90 2.5 Turbo.
Onboard computer states I get an average of 15mpg but when I refuel and divide miles driven by fuel added, it equates to 22mpg.
The check engine light came on a month ago. Did diagnostic scans from multiple auto repair shops with a code of P2177 (bank 1 lean). I have replaced the MAS (diagnostic reveals 0.83 mg/cm when it should be 1.0 thus the CPU is adding more fuel to compensate for lower value on MAS,therefore, onboard computer shows lower mpgs and triggering the check engine light). I also replaced the fuel pressure sensor, fuel filter, and upstream O2 sensor. Did not take care of problem and still pulls code. Took it to a Volvo dealer yesterday. Their diagnostic reveals the following:
ECM-212C (Long term fuel trim, bank 1 - Signal too high
ECM-21EC (Long term fule trim, bank 1 - Signal too high
Tech at dealer replaced the following to attempt correcting the problem:
Oil trap & attendant components, cleaned throttle & PCV nipple, downloaded ECM software upgrade and replaced various hoses.
They obviously don't know how to fix it. Does anyone know if it is a correlation between the onboard computer and acutual mpg, which pulls the check engine light???????
Old Dec 18, 2010 | 10:30 PM
You posted this in the S90 section. You need to get it moved to the proper area of the forum.
lysmykita
Oct 23, 2008 03:26 PM
DINOVIO
Aug 24, 2008 12:47 PM
Typhoon
Aug 22, 2008 07:26 PM
stevie123
Mar 2, 2008 09:12 PM
Musicjunkie2k
Oct 22, 2005 07:27 PM
