Driver door cylinder replacement
Old Mar 10, 2011 | 04:06 PM
londe's Avatar
Default Driver door cylinder replacement
The driver door lock fails to return to neutral after unlocking.
I have removed the door panel and insulation, the two screws in the posterior door under the door lock and the two more superior vertical screws in the posterior door.
Any further guidance would be helpful. thanks in advance. Londe
Old Mar 11, 2011 | 03:52 PM
Can you see in there? Should be just a clip on the inside and some hook lever. Sounds like the old return spring broke.
Old Mar 20, 2011 | 07:58 PM
londe's Avatar
Default re drive door cylinder replacement
I figured it out. The antitheft device slips forward
and allows for removal of the door lock assembly.
The spring had slipped from from the turning post
producing a loss of tension in the door lock assembly.
I repositioned the springs and it works as designed.
thanks
Lgbpop
May 26, 2021 03:34 PM
Newport_j
Oct 18, 2014 03:55 PM
guest01
Apr 4, 2014 12:20 PM
twdubs
Jul 4, 2009 12:51 PM
shrinehart
May 16, 2008 05:53 PM
