silverS90 |
12-23-2015 01:29 AM |
New guy with questions
Hi all. New to the forums and new to Volvos. Just picked up a 1998 S90 for a daily driver, bc apparently there isnt a large aftermarket parts/performance upgrades selection... unless you do a swap or spend crazy $$$ on custom parts. and i wanted a car that would keep me from doing that to it.. just keep it serviced put gas in it and drive it. Not new to cars as i recently got rid of my favorite car ever a Toyota Supra. Tastefully modified of course. to the point of this post, i am having an ac airflow issue. I have checked the intake vent under the wipers and it appears to be clean. you can place your hand over the vents and feel light suction. As you change the fan speed selector 0-5 you can hear the change in speed with each selection, but the force of the air coming from the vents does not change no matter if it ac or heat or on recirc. Have been reading on the forums for the past few days gathering information about this issue but most of what i have read states that one side is blowing cold the other hot, or that it blows cold for a bit then warmer. Mine isnt doing either. When you select ac you can feel that the little bit of air coming from the vents is in fact cold and when on heat it is in fact hot. Just trying to figure out why no matter what i select face, floor, defrost, face/floor mix its the same flow speed of air no matter the speed selected on each option. Any ideas what could be causing this?
Any help would be greatly appreciated
