running hot
Old Feb 7, 2012 | 11:19 AM
rlum's Avatar
Default running hot
started my s90 up this morning and not even 10 min in my thermostat gauge shot up to the red line. gased it and it went down, fan works. when coming to a stop it heats up again what could the problem be.
Old Feb 7, 2012 | 02:05 PM
rlum's Avatar
i guess this is not an everyday disscussion
Old Feb 7, 2012 | 03:52 PM
Hi rlum, welcome to the forum.
I'd like to first let you know that I think you should pull over and shut the car off when you see it overheating.
Next, you likely have a bad water pump, thermostat, or coolant leak somewhere and need coolant. What have you done to find the problem so far.
If you KEEP DRIVING you can destroy the motor when it over heats. i.e. Blown head gaskets, burnt valves, blown coolant hoses, crack blocks, etc. are all results of an over heated motor.
Old Feb 8, 2012 | 10:31 AM
rlum's Avatar
theres no leak of any coolant, water pump ,thermo,hoses looks like i should just change it all. thanks
Old Feb 15, 2012 | 11:36 AM
I once purchased a S90 with a broken water pump. The perpeller was broken off the pump inside the motor. I would remove the thermostat and see if that helps. If it stops running hot after that, install a new thermostat.
If it still tries to run hot, have the water pump replaced. Here is a pic of my bad pump. Sorry I didn't see your reply sooner.
Old Feb 16, 2012 | 04:04 PM
rlum's Avatar
thanks for the input anyways i changed my engine temp sen and all is well
Old Oct 31, 2012 | 10:53 PM
pjessmaster's Avatar
Mine does the same when I drive the car for a while and come to a stop. If I'm stopped for a while the car starts to heat up gradually. When I'm driving its never an issue. I flushed the system running a new thermast and water pump. New coolant of course. Also bought a brand new coolant resivore cap. When it starts to heat up the coolant cap starts to over flow. Any suggestions ?
Old Nov 1, 2012 | 09:10 PM
Henry10's Avatar
Like Rspi said, take out the thermostat and see if problem persists. T might be faulty or installed backwards (altho not sure if this can be done).
Old Nov 4, 2012 | 10:00 AM
It would heat up without the thermostat before. I haven't tried it after I bought all that. It's on heats up after its been drivin and then stopped though.
beardo265
Sep 27, 2007 09:24 AM
dbaldock
Jun 28, 2005 07:33 PM
auburnjosh
Sep 17, 2004 12:40 AM
auburnjosh
Sep 6, 2004 11:31 AM
