03 V40 software upgrade seeking pros/cons
I recently got an 03 V40 , as it is throwing 3 codes 0507 0171 0442 & although check engine light had gone off it is back on
I need to get her smogged next week I have been told a software upgrade at dealer will help , It is about 120 miles rountrip and gas is hitting 375 in my area , has anyone had this done??
software update is not needed here. Your fault codes are pointing to an intake air leaks somewhere. Do a search on P0507 on the board and you will see a suggestion to check one of the vacuum hoses down by the intercooler which can cause a leak and throw this code. The 0171 is a fuel trim code, indicative of an intake air leak as well and the 0442 refers to the evap system which also has a vacuum line. Typically the 0442 code is caused by the j hose going into the carbon cannister in the rear quarter by the fuel tank so check Google/Youtube for how to inspect that hose.
Luke Woessner
Oct 29, 2018 10:09 AM
! I will do that right now , I had it smoke tested and they found nothing , Is this something that could have been missed ?
