2000 V40 alarm system
Old Jan 26, 2005 | 03:58 AM
gmyoryi's Avatar
Default 2000 V40 alarm system
That any body know how the alarm work in the 2000 V40, the red light on RT. side of the dash is off all the time. I check all the fuses and the are ok.
Thanks
George Montore
Old Jan 26, 2005 | 09:45 AM
Default RE: 2000 V40 alarm system
Are you sure your car has the alarm system.That light assy. is more than just an alarm led?If you do have an alarm that works the led might be bad.
Old Jan 27, 2005 | 04:57 AM
gmyoryi's Avatar
Hi Tech!
I'm not yure if my car has factory installed alarm, but I noticed that my remote control to open the car has a panic buton and when I press the red buton the blinkers lights start to flash and the horn starts to beep. I lift up the led on the RT. side speaker and I found the wires conected to the light.
I let the driver side window down and I lock the car with the remote, and if I rich inside and open the door, the alarm never goes off.
Do you know a way to find out if the car has factory installed alarm?
Thanks for the HELP!!!!!!!!!!
George Montore
Old Jan 27, 2005 | 09:49 AM
The only way I know of is to have the dealer look in the programming on the car.After you lock the car did you wait about 2-3 minutes before trying to open the door.One more thing to try is once you lock the car with the remote and wait a couple of minutes try reaching in and pulling the hood release and see if the alarm goes off.If not you may want to have the dealer check for codes and make sure you don't have a bad door lock.There must be a reason why the alarm isn't arming.
tonyfirshman
Aug 7, 2012 05:47 AM
ddrewyor
Jan 8, 2012 03:36 PM
abc05
Feb 2, 2010 05:10 AM
Garon
Apr 22, 2009 02:57 PM
