2ooo V40 immobilizer
Old Nov 18, 2004 | 07:48 PM
gmyoryi's Avatar
Default 2ooo V40 immobilizer
HI!!!
I like yo know howe the immobilizer work in this V40.
My car start but die one second after the engine fire-up.
Old Nov 18, 2004 | 11:28 PM
Default RE: 2ooo V40 immobilizer
Look bye the speedometer and see if a light of a little car is flashing fast if so its not reading the key.
Old Nov 19, 2004 | 01:09 AM
gmyoryi's Avatar
Hi Tech
When I turn the ignition key to ON position the little car light is on and after 2 or 3 seconds it turns off. Does this mean that the immobilizer is working?
Old Nov 19, 2004 | 09:49 AM
Yes that means it is working.Check all your fuses in teh engine compartment.There is a turbo valve in the induction valve that goes bad and when it does the car acts this way.If there is a blown fuse you will have to unplug the valve on the hose replace the fuse and the car will atleast start.You will have to replace the valve.
KREID
Jun 23, 2021 02:37 PM
ddrewyor
Jan 8, 2012 03:36 PM
Garon
Apr 22, 2009 02:57 PM
shpeedy
Sep 26, 2006 08:08 PM
benbtj
Apr 9, 2006 04:55 PM
