Immobilizer Light
Old Apr 13, 2005 | 10:31 PM
KREID's Avatar
Default Immobilizer Light
This past winter I have had a problem with my immobilizer light coming on when the ignition has been turned over. The light will remain on untill the ignition has been switched off. Has anybody encountered this problem & if so how can it be fixed/managed?
Cheers!
Old Apr 14, 2005 | 12:05 AM
Default RE: Immobilizer Light
That means that the signal was missing from the key.There is a fault somewhere between the key and the immoblizer.
Might be the key.
Might be the antenna for the immoblizer.
Might be the immoblizer.
Old Apr 14, 2005 | 12:13 AM
KREID's Avatar
Thanks Tech,
I will speak to my service provider to have them check this out. Do you forsee any problems associated with this concern or will I be ok to drive my 40 when this light is still on?
Old Apr 14, 2005 | 12:23 AM
It shouldn't run when the light comes on.That means there is no signal from the key to the immoblizer.
Old Apr 14, 2005 | 12:26 AM
KREID's Avatar
Thats the strange part about it! The car will turn over, the light will come on & stay on untill I cut the engine.
Old Apr 14, 2005 | 10:01 AM
Yes that is strange.It is supposed to stop the engine from running when the light stays on.
Old Jun 23, 2021 | 02:37 PM
dondo3's Avatar
this is an old post but hopeful to get an update or what’s going on because I have an 05 s40 that would crank start then immobilizer lights came on and car would die out I still can’t start as of 6/23/2021
kkboyvolvo
Feb 14, 2009 04:00 PM
jabbo
Dec 27, 2006 09:24 PM
yousefkali32825
Sep 23, 2006 07:31 PM
benbtj
Apr 9, 2006 04:55 PM
gmyoryi
Nov 19, 2004 09:49 AM
