Broken brake hose bolt
Old Aug 12, 2023 | 11:34 AM
Mellemo's Avatar
Default Broken brake hose bolt
Hello, after noticing my brake hose had a hole in it I bought a new one, successfully unscrewed the bolt that held the other end but got this one completely rounded.
Now, I was wondering how to go on about this, should I get a saw and just split it and weld it onto a new screw?
Old Aug 12, 2023 | 11:57 AM
You don't "weld" a new fitting onto the end of a brake line.
Go look at metal brake lines at the autoparts store to see how they work. You're probably going to have to replace that metal line. And the ones you buy at the auto parts store usually don't fit. They have the wrong type of flare and the threads might be different.
In the meantime you will need penetrant and maybe so heat to attempt to loosen that - but it may be too corroded by this point
vove
Jun 7, 2022 11:22 AM
pauldohey
Dec 10, 2021 03:26 PM
KaylaBishop
Apr 29, 2018 05:24 PM
gdog
Nov 28, 2013 07:38 PM
edahlgren
Aug 16, 2009 02:34 PM
