code P0303 2004 v40
Old Jan 5, 2009 | 10:03 PM
dan42's Avatar
Default code P0303 2004 v40
While speeding up at wot, car begin to shudder and surge. CEL blinked several times before it stay on. After this car would shudder under part throttle and while stopped at traffic lights.
I have done the following,
Changed plugs and gapped to .028.
Changed #3 coil.
Changed fuel filter.
Swapped #3 injector with #4 injector.
Test drove after each change. Only noticably improvement was a smother idle.
Car has 93500 miles and was last serviced at 90000 miles. Plugs. air filter, oil change and filter.
Plugs I took out looked good.
Did compression check and all cylinders were app. 170 on 4 revs.
Car still shudders, surges and bucks under wot.
Got the following codes after last drive:
P0303 (twice)
P0301
P0302
P0304
Any input greatly appreciated.
I have owned car since 51000 and these are the first proplems.
Old Jan 5, 2009 | 10:12 PM
Default RE: code P0303 2004 v40
How about the other coil and the 2 wires?
The check engine light flashing means it is misfiring.
Old Jan 5, 2009 | 10:22 PM
dan42's Avatar
Will replace other coil tomorrow and order wires.
Thanks for reply.
Old Jan 6, 2009 | 06:18 PM
dan42's Avatar
Changed #4 coil. Went for test drive. No skip, no misfire, no bucking and surging. WOT from dead stop produces wheel spin and best of all NO CEL flashing or staying on. Hopefully problems solved with 2 new coils. Just dont understand why #4 coil would produce P0303 (which it did today after clearing last night) instead of P0304
Many thanks for input.
Old Jan 6, 2009 | 07:11 PM
Glad all is good now. Not sure why it threw that code either but all that matters now is it is running good.
If you didn't replace the wires yet I would soon.
Old Jan 6, 2009 | 10:25 PM
dlk1's Avatar
Am I missing something? On the '40's, how can you replace the coils without changing the wires. Its all one item.
Old Jan 7, 2009 | 07:13 AM
No there is 2 coil packs and 2 ignition wires.
Old Jan 7, 2009 | 02:46 PM
dlk1's Avatar
of course..... brainfart time!
ColoradoSoul03
Jan 28, 2014 04:11 PM
wingzeroac195
Nov 11, 2011 07:47 AM
drummertom
Aug 15, 2011 06:15 AM
zerofallout
Oct 27, 2010 06:11 AM
johndeer.buck
Sep 2, 2010 10:52 PM
