2000 volvo s40 code p0303
Old May 2, 2010 | 03:42 PM
wingzeroac195's Avatar
Default 2000 volvo s40 code p0303
Good Day everyone, I just bought a 2000 S40 and has 155000, the car run good, is rough to start(takes about 5-8 second to just start, like if it was not furl, but the pump works), I heard is the fuel pressure regulator that I need to replace, but that is not my only problem, yesterday the CEL came on with the code P0303 misfire cylinder 3, so I check the coils and replace the spark plugs, but the code came back again, does this has anything to do with the long cranking? should I replace the fuel filter since probably the previous owner never did? please give me your expert advice, thanks
Old Nov 3, 2011 | 09:49 PM
JayTee's Avatar
Default 2002 s40 P0303 Cyl. 3 Misfire
Had a hard time finding this one which turned out to be a bad connection inside the fuel injector connection-used Ease Diagnostics on laptop together with Snap-On lab scope and spark tester attached to windshield wiper all at once to find. Recorded everything then went back to trigger point and found the injector was "missing" under load, higher RPM and the warmer it got the worse it was. took 3 days to find.Hope this helps someone else.
Old Nov 8, 2011 | 04:28 PM
Cavpilot's Avatar
So, after you isolated the problem, what was the solution?
Old Nov 11, 2011 | 07:47 AM
JayTee's Avatar
Default Volvo s40 P0303
The fix was to take the connector apart, repair the loose wire to metal connector, tighten the "squeeze" where the connector holds on to the injector and reassemble the connector.
bringit8435
Dec 6, 2012 02:01 AM
drummertom
Aug 15, 2011 06:15 AM
zerofallout
Oct 27, 2010 06:11 AM
johndeer.buck
Sep 2, 2010 10:52 PM
dan42
Jan 7, 2009 02:46 PM
