Maddening '01 V40 Rear Wiper Behavior
Hello Group,
Recently I replaced the rear window wiper with a V40 OEM blade from the local Volvo repair shop.
I clicked the new wiper into the arm no problem and drove off.
Since then, the wiper lifts off and does not wipe the rear window during a portion of its stroke:
[ol][*]From 0 to 45 degrees OK[*]From 45 to 135 degrees lifts off and does not wipe[*]From 135 degrees to 180 OK[/ol]The above behavior leaves a pie slice or wedge shaped pattern in the middle of the window............
The wiper blade is symmetrical. The wiper arm is not loose. The wiper arm has a plastic U-shape structure to it, it is not the all metal version.
Anyone out there with any insights ?
Thanks,
UJ
Thanks,
UJ
Yes I have this exact problem too. I'm going to try to bend the arm. It is mostly plastic, but the lower portion is metal, so I'll try to bend it in a Vise a little bit. It is really maddening. A new wiper arm is $38 from Volvo, but I don't want to spend the $$ unless I'm sure it will actually fix the problem. I'm afraid I'll just end up bending the new wiper arm to make it work!!!
Nick
04 V40
07 9-3 SC
Nick
04 V40
07 9-3 SC
Ok so I was able to fix it. Bending the bottom metal part of the arm is out of the question b/c it's really heavy steel. What I did was removed the spring and used a file to grind down the plastic part of the arm where the limit stop for the spring-arm travel is. This allows the spring to pull further than before, so that the arm can keep pressure on the window glass at the top position.
Hope this helps.
Nick.
Hope this helps.
Nick.
![Thumbs up](https://volvoforums.com/forum/images/icons/icon14.gif)
Thanks for all the suggestions. I've had this problem since I've had the car (nearly 6 years) and this is the first time I've had any success. The two stops mentioned are easily filed off and as it's a plastic moulding I also used a sharp, narrow wood chisel to get the last bits off. Fitted a new Bosch blade and it's brilliant! It's never worked so well since I've had the car.
brettmhatch
03-21-2011 08:34 PM
