NEED HELP!! 2001 V40 Timing belt change
Old May 13, 2018 | 12:29 AM
Noah Peters's Avatar
Default NEED HELP!! 2001 V40 Timing belt change
I have this 2001 Volvo v40 that needed all the front seals replaced so in the process I was going to change the oil soaked timing belt. Only problem is I forgot to set TDC for the crank pulley before accidentally came off. So the current state is that the timing belt is off and I have no clue if cylinder 1 was on compression or exhaust stroke. I know I can find TDC through spark plug hole with a long metal stick but won't it matter if it's compression/exhaust stroke? I need someone who's been here or knows more than I to help me out because I'm screwed right now! Thanks for any help/advice.
Old May 13, 2018 | 01:06 AM
jefe's Avatar
Has anything shifted since you took the timing belt off? Could you put the timing belt back on, tighten it, and then set to TDC?
Old May 13, 2018 | 01:23 AM
Sadly, yes. Give or take one rotation. Timing belt is off as well as the crank pulley.
Old May 13, 2018 | 08:21 AM
the reference to exhaust vs compression stroke is for the cam to crank timing. think of it as the cams turn twice for every turn of the crank so the piston is TDC twice in each cycle. If you can guess TDC with a rod, then you can set cam timing via their marks. This means your question is how do you know if you are 180 off or not. Google for some tricks on how to determine that and you should be on your way.
Old May 13, 2018 | 12:26 PM
jefe's Avatar
This is interesting. Might spark an idea.
Old May 20, 2018 | 12:30 PM
Rich F's Avatar
Cool
I should point out that one of the contributors above made a mistake ----it is the crank the turns two rotations for each single rotation of the cam.
Old May 20, 2018 | 01:10 PM
correction noted :-)
SoK66
May 2, 2014 05:39 PM
Jeffers
Jan 1, 2014 01:25 PM
Magic_Don
May 1, 2011 09:33 PM
kingmf
Feb 17, 2010 10:07 PM
Speedy84
Nov 7, 2007 10:19 PM
