oil leak issue
Old Nov 4, 2012 | 08:17 PM
nasko00v40's Avatar
Default oil leak issue
hello I am new to the Volvo scene. i got my wife a 00 V40 from the auction for 1500$ it has 144K, dark blue in mint condition. When I got it home parked it in the garage over night. I pulled out the car this morning, and saw a oil stain I looked under the car it looks like it might be coming from the oil plug but not sure. my friend said it might be coming from the turbo or turbo oil lines.I ran Sea foam through the motor, and honey motor stop leak. Also my wife would like to know when the turbo kick in @what RPM. and also what does the S button do?
Thanks for the feedback
Cheers
Old Nov 4, 2012 | 11:13 PM
migbro's Avatar
my friend said it might be coming from the turbo or turbo oil lines Your friend is correct. It's coming from the turbo oil drain line o-ring seal at the block.
Bad idea.
the turbo kick in @what RPM The turbo does not "kick in." It makes boost progressively up to 8.8 psi throughout the rpm range dependent on throttle setting.
what does the S button do? Press the S button to select transmission Sport mode. The transmission shifts up and down at higher engine speeds for improved performance. The red LED in the button comes on to indicate that Sport mode is selected.
Old Nov 5, 2012 | 09:19 AM
Richard1's Avatar
It maybe leaking from oil pan or transmission lines but I am not sure.I think you should go to your local car parts place and they will have products that will clean it up. Usually a kitty litter substance soaks up oil well. Find out where the leak is and have it fixed.
Old Nov 5, 2012 | 08:34 PM
nasko00v40's Avatar
I thought thew turbo kick in at certain RPM like 2500 RPM or 3000 RPM? not like a supercharge its running from idle. Also whats the max LBS of boost is this turbo running at and what kind of turbo is it? is it a T3/T4 or something? Also can I hook up a boost controller and increase the boost on it? Its my wifes car but i can get a used boost cotroller from a buddy for pretty much free. Is it worth increasing the boost?
Old Nov 7, 2012 | 11:48 PM
migbro's Avatar
Your rite the tubo kik in at 2684 rpm as far as max boost i think i said befor it was 8.8 psi its not a T3/T4 so it must be something. I wud def get a pretty much free boost cotroller. hook it up you wil not be disappoited.
Old Dec 10, 2012 | 08:24 AM
danial76's Avatar
What might cause an Oil Leak? What mainterneance issues cause this possibly and what can prevent it?
Maintenance issues with oil leaks?
In general what can be done to keep an engine in tip top shape
specifically for Chevy "Cavaliers" or any cars?
xxblindxx
Jun 23, 2016 11:06 PM
craigshensel
Jun 22, 2012 06:08 PM
ROBLU540
Feb 20, 2009 07:59 PM
jeannelw
Nov 18, 2005 10:05 PM
witstaffy
Jul 25, 2005 09:31 PM
