Alternator Replacement
Old Sep 29, 2022 | 01:01 PM
adobejoe's Avatar
Default Alternator Replacement
The oil dipstick was left up an inch and oil sprayed out and covered the top of engine and alternator. Drove quite awhile and now it appears alternator has shorted internally and drains battery and is not charging. I assume alternator toast. To remove it looks like it raises UP rather then down as some videos show? I assume, disconnect all power and electric leads, loosen belt tensioner, remove three bolts for alternator and lift up and out? Can anyone confirm?
Old Sep 30, 2022 | 10:22 PM
adobejoe's Avatar
No one replied. I figured it out.
remove right front wheel
remove inner liner
loosen belt and remove
disconnect battery and leads
remove air ducting
loosen three 10 mm bolts
carefully remove out top!
Dave Jones
Mar 27, 2018 10:17 PM
rloomis482
Dec 17, 2013 08:23 PM
pdb1465
Oct 21, 2010 11:16 AM
alabama1
Sep 30, 2010 02:33 AM
saluki_s60
Jul 2, 2008 06:42 AM
