Buying a 2006 V50 on Wednesday, what to look for
Old Nov 22, 2015 | 11:12 AM
avenger09123's Avatar
Default Buying a 2006 V50 on Wednesday, what to look for
Hey guys and gals of the Volvo Forums,
I am trading in my gas guzzling wallet-nightmare of a truck that I love dearly, for something a bit more economical being that I am now no longer in the military and going to school.
I found an AWD T5 automatic with 111,000 on the clock w/ a Single Owner.
First: Any warning signs to look for when I go for a test drive?
With 111,000 on it I planned after getting it home to put new plugs, coils, injectors, belt, air filter, and then taking it to a shop and getting a tranny flush/coolant flush.
From the owners here, how easy are the differentials to change the fluid out of? And in regards to them, are they limited slip or when I slide will I send all the power to one wheel and buuuuuuuuurrrnnn some rubber?
Old Nov 22, 2015 | 03:37 PM
ES6T's Avatar
Leaking struts are common. Control arm bushings are common.
Timing belt is due soon (10 years or 120k)
Replacing injectors is a waste of money.
The differential is electronically controlled limited slip. The fluid is a lifetime fluid. There is no drain, so you have to suck it out if you want to change it.
Old Nov 22, 2015 | 03:53 PM
Thanks for the info!
I have no problem replacing struts as needed.
Control Arm Bushings - Are these a nightmare to do ourselves? Is it worth it to antisieze the crap out of a new set or are they just going to be a nightmare no matter what?
Timing belt - I read through a sticky on here how to replace it, so that won't be too bad.
Injectors - Why do you consider changing them after 100k a waste of money? I've never known an injector to have the same efficient spray pattern at brand new as at 100k due to the weardown.
Differential Fluid - Lifetime you say? Interesting. I have a suction gun. But I suppose as long as nothing gets into the boots and into the system and nothing overheats we should be good to go.
Thanks for your input I appreciate it.
Old Nov 22, 2015 | 09:10 PM
ES6T's Avatar
The busings are part of the arm. Not too bad if the bolts are seized.
Volvo's rarely have injector issues. I didn't know you were doing it for efficiency though. I've never had injectors sent out and checked, but I have consistently gotten the same MPG in my car from when I bought it at 25,000 miles until now at 150,000 miles. So spending several hundred bucks on new injectors would hardly be worth it to make up such a minute difference in efficiency.
cmg212
Sep 12, 2015 02:01 AM
fcpgroton
Oct 9, 2012 09:41 AM
fcpgroton
Oct 9, 2012 09:40 AM
STREETFIGHTER50
Feb 7, 2012 12:50 AM
HelgaTheS80
Dec 16, 2006 01:38 AM
