-   Volvo V50 (https://volvoforums.com/forum/volvo-v50-20/)
-   -   Central Electronic Module (CEM) question (https://volvoforums.com/forum/volvo-v50-20/central-electronic-module-cem-question-94466/)
partemisio Nov 8, 2017 07:26 AM
I have a 2006 V50 that I just replaced the Central Electronic Module (near passenger feet) in because I found water intrusion when diagnosing a no start. The car still will not start. Does this module need to be programmed? And if it does, can it be programmed multiple times (I got this used off another car).
The Thong Nov 8, 2017 11:06 AM
Yes, the dealers will have to code it. Have you purchased a second hand one or is it new? As far as I’m aware, once they’re coded, they can’t be coded again. Speak to your local dealer.
TT
FREE-PPV Nov 8, 2017 07:59 PM
I had same problem, took off cover to evaluate, a lot of white corrosion was visible, so bought some electronics cleaner, got tooth brush and cleaned all areas of corrosion, always on top PC board in my experience, put it under heat lamp to dry out, solved problem of no starting.
When you replace with used CEM, you could be adding problems, but dealer will need to recode.
Good luck,
The Thong Nov 9, 2017 01:22 AM
A quick how to clean your CEM link
https://ozvolvo.org/discussion/5649/...ctronic-issues
partemisio Nov 28, 2017 02:27 PM
Thanks for the replies guys. I will try cleaning it myself. I did take it apart and saw the corrosion was pretty bad but I'll try cleaning. If that doesn't work, do you know of somebody that it can be sent off to to get fixed? I know there are companies that do it for things like gm gauge clusters. I just hope it's the only problem cause the only thing on the gauge cluster that works is the check engine light. The radio doesn't work and the hvac is hit or miss. Also won't try to start.
FREE-PPV Nov 28, 2017 02:55 PM
You will solve most of these ghost haunting problems by simply thoroughly cleaning corrosion which is easy to see as you found out. Concentrate on those areas, and push tooth brush and electronics cleaner under all connections and IC chips on top PC board which is ironically the only PC board which isn't coated in plastic dip and the one most exposed to water damage. Crazy, but then again, Volvo's are made to break down so you have to go back to dealers. lol Make sure you correct water issue, cowl drain tubes get blocked along with sun roof drain tubes, so then seal top of CEM with some good silicone sealer.
Good luck,
partemisio Nov 28, 2017 04:40 PM
Good luck,
I'll give it a try this weekend and report back. Thanks for the help!
partemisio Dec 26, 2017 12:39 PM
I took the CEM apart and found corrosion on the inside. I was able to clean all of that off. Car still won't start but has less codes. The cide thats keeping it from starting is 720A whuch is an immobilizer code. I cant dind much indo about diagnostics for the code though. If anybody has a diagnostic procedure for this code that would be awesome.
The Thong Dec 26, 2017 12:58 PM
If the battery had been off the car long enough the car can lose the immobiliser code, this will have to be reloaded by the dealer I’m afraid.
Still Goin' Apr 28, 2022 10:41 AM
Thanks to FREE-PPV. When I took the cover of my CEM off I saw just a bit of corrosion. I cleaned it off with methyl hydrate and a toothbrush then I applied some dielectric grease to prevent further damage. So far it's working just fine.
user 76290820 Feb 9, 2023 10:02 AM
Transfer the chip
Just wanted to put this here:
If your CEM is ruined you can buy a used one cheap on eBay and get someone skilled at soldering to swap your chip onto the board, I paid $40 for the new used CE? and $50 for the work.
As far as I know, no one has found the source of the leak. I packed absorbant material above the green connector to catch it.
mt6127 Feb 9, 2023 05:22 PM
XeModex will rebuild them as well. They also have some trouble shooting info on their site
Ronnieboy Feb 9, 2023 06:40 PM
There's a couple of ways to deal with it. Buy a new CEM and have it programmed at the Volvo dealer or Independent that is capable. The other is to send your old one to XEMODEX. Read all of their info regarding P1 CEMs.
Central Electronic Module for Volvo | XeMODeX Inc.
user 76290820 Feb 21, 2024 09:30 AM
better solution and the big question
If you buy a used module, I figured out you can remove the main chip from your old board, and solder it to your new one. I had a local guy do it for $50
Also, did anybody ever pinpoint the source of the leak? I've only heard speculation.
