DPF sensor
Old Jun 30, 2022 | 07:49 AM
jackv50's Avatar
Default DPF sensor
Hello,
Recently, the engine light, emergency mode, codes P2452, P2453 (Pressure sensor particulate trap Faulty signal). I had the sensor replaced, reset on the diagnostics (Vida in Volvo). The car drove normally and after a week the problem returned. The sensor was replaced again, again in a week and the same problem. Why does this sensor always die? Almost no soot inside.
CAR: VOLVO V50 2.0D 100kw
If anyone can advise me, I will be grateful.
Thank you.
Old Jun 30, 2022 | 10:58 AM
Dingus1's Avatar
Usually when you get a code for a sensor, the sensor is not the issue. The code is telling you that the sensor is reading data outside of the set parameters.
Check to make sure your car has enough DEF in it to start.
Dunlin1
Volvo XC40
Aug 24, 2021 03:54 PM
91shelby
Feb 15, 2013 03:22 PM
rfa803
Aug 2, 2010 10:40 AM
Krle
Apr 1, 2010 03:33 PM
topdwn
Jan 24, 2006 10:39 PM
