HVAC problems
Old 10-09-2009, 11:52 AM
hartotis's Avatar
Default HVAC problems
Had a problem come up last night, on the coldest day of October naturally. When I turn on the defrost button on the centre stack (goes to max defrost and turns on the A/C for it) I can hear the fan blowing but I get almost zero air flow to the windshield. Also, when using the auto climate system (set at 28C) I get heat out of the vents on the driver's side but, I get cold air blowing out of the passengers side vents. The car is still under warranty so I am not too worried about any charges but I am curious if anyone else has experienced this problem and what was repaired to fix this problem? Car is 2007 V50 with 65,500 kms on it.
Old 10-09-2009, 11:28 PM
AutoNaut's Avatar
This is another one of those known S40/V50 quirks. The HVAC servos can get out of sync and it does exactly what you described. I had the same problem about a year ago. Unfortunately, all you can do is take it to Volvo service and have them do their magic (software reload / calibration). I believe that there is a software update that attempts to fix this issue.
Stan
Maxbaby
12-24-2011 09:38 PM
tn850
12-05-2007 07:20 PM
Maxbaby
04-18-2007 03:16 AM
850forum
02-25-2007 01:51 AM
Air Defender
03-02-2005 02:29 PM
Quick Reply: HVAC problems
