93 850 HVAC - damper motors again
Old Apr 19, 2007 | 04:56 PM
Maxbaby's Avatar
Default 93 850 HVAC - damper motors again
As posted earlier, I just replaced the floor/defrost damper door on my HVAC system, necessitation the complete removal of my dash, and of course, the removal of the damper motor. The shaft on the damper door had split and broken apart who knows how long ago.
This means that the motor position may be anywhere in its travel, so I don't know whether to open the damper and then install the motor, or close the damper and then install the motor onto the shaft... What I was thinking was, open up the damper motor and reposition that cam into the middle of its travel so that I know to have the damper door in the halfway point... does anyone know if this will work or if it is even necessary? I know I'll still have to do that "learning" mode, but I want to make sure that I don't twist off the new shaft after the initial try...
Old Apr 21, 2007 | 09:15 AM
JPN's Avatar
JPN
Default RE: 93 850 HVAC - damper motors again
Hello mate,
I am not sure as to which damper motor you're working on, and I myself have not performed damper motor servicing. I'll attach a pic and see if you can mark which motor you're working on. Someone else may be able to direct you to the right direction.
I'll delete the pic within the next 3 days so make sure to save it in your PC.
Cheers,
JPN
Attachment deleted.
Old Dec 24, 2011 | 09:38 PM
Why delete the picture ?? I'm trying to identify all the motors on my 95's system.
gentlejax2
Sep 27, 2012 07:55 PM
JT17LV
May 1, 2012 10:03 PM
Kiss4aFrog
Dec 25, 2011 03:06 PM
Jordan16180
Mar 9, 2009 09:45 PM
plopezxx
Nov 30, 2008 07:07 AM
