Turn signal wand needed or is there an adjust
Old Jan 28, 2017 | 03:28 PM
urdrwho's Avatar
Default Turn signal wand needed or is there an adjust
Within the past week when I flip the headlight high/low beam on the turn signal wand the right turn signal comes one. You have to be very careful, if the wand moves anywhere toward turning the right signal on it will illuminate the right signal. This is not so for the left signal.
I am in need of replacing the wand or is there an adjustment. There is probably some detent in there or something that has worn out.
Urrg. In two years of ownership this V50 has more needs at 103,000 miles than the 4 years of owning the S60. And the S60 had 197,000 on it when we got it.
I'm guessing that there are three torx heads underneath the base that hold the clam shell cover over the wand. It shouldn't be too hard to replace.....I think?
suckonthiscaravan
Dec 5, 2018 03:19 PM
dottesen31
Sep 2, 2013 05:33 PM
donf
Oct 25, 2010 10:38 PM
brennanpersonal
Nov 4, 2009 10:33 AM
rspi
Sep 2, 2009 09:39 PM
