V50 instrument cluster removal
There are many things across the Internet about removing instrument clusters for other Volvos, however for the V50 there appears to be nothing, therefore I am starting this thread. Unlike other models for our V50 there are at least two sets of wires connected to or strapped to the instrument cluster external housing, and I am reluctant to try to remove these for fear of breaking them, and not knowing which tools to make things simpler and prevent said breakage. On the lower right in the photo you can see a wire bundle with yellow and orange wires and done on the upper right-hand side you can see another set of wires which run across the top of the housing. Unlike for other models there are only two screws that secure the instrument cluster to the car then there are two that further secure the trim. So I am stuck on the two clusters of wires that are strapped or connected to the instrument panel housing. Any input would be greatly appreciated. https://cimg3.ibsrv.net/gimg/volvofo...042156413.jpeg https://cimg4.ibsrv.net/gimg/volvofo...00289a2fb.jpeg |
AFAIK,
Remove the two screws (one on the left the other on the right) lean cluster forward and remove green plug on the top maneuver cluster so to get the left side out as far as you can (the wire on bottom plug is very short and will not allow cluster to come all the way out) with left side out, lean cluster to the right and with your left hand unclip/unplug the white plug-- (push in on release tab while pushing down on plug or wires) -- you will not be able to see what your doing. Alternately, remote the lower panel (above brake and acc pedal) and cut the wire tie for that harness --- this will free up a few more inches of wire to allow better access to plug. |
Apart from the two screws there is clip top rear that holds the cluster in place. I broken mine getting the cluster out but it's no big deal. If you were to try and get it out without breaking the clip you'd need to somehow lift the cluster straight upward wards about 1.5cm then pull/tilt it forward from the top. Tilting forward from the bottom won't fly.
2004 V50 T5 Stock |
