Volvo V50 D3
- Hello to all 🙂
In a bit of a quandary with my current ride (2011 V50 D3 5 cylinder) really need some help/advice if poss off you guys/girls.
The car has full history, average miles for age, and goes like stink 'once started' but sometimes it refuses to start, it might click, part crank over, or do nothing at all ! and now more recently splutters on firing then cuts out (50% of the time) resulting in me frustratingly turning the key on/off and trying again until it does fire up.
I initially thought the SCU was at fault after looking on the forum pages and it being a common problem on this platform, but now suspect it is something further on after this point ?
So far it has had a new premium battery, all filters/service etc, new fob batteries, and today went to a Volvo specialist for Vida diagnosis all to no avail, his words where 'its a bit of a strange one this' , no fault codes whatsoever ! I said to the guy 'I'm fed up with this, think I might sell it' to which he replied 'see how you go and what develops in the future' he also added it started 90% off the time we had it in, but on a short test run he'd turned it off and then the car refused to start again(momentarily).
Really dont want to bail/give in on this car but just don't know what to do next, I suspect it's fuel delivery, injectors, leaks in hoses maybe but surely it would not run right once started if that's the case ?
#baffled
clicks or no turning over at the start suggests that you may have an issue with cables, ground points or the ignition switch. If you have a fuel delivery issue, I'd think it would at least turn over but may not start. Leaks in hoses would not likely cause a no start unless its blatent like the intake air tube falling off... and those typically do throw a code
Hi, thank you for the reply.
It has had the starter motor checked plus all ground/earth points cleaned. I had the cem out of the pass foot well, I'd expected some corrosion possibly but was clean as a whistle.
The day after the Vida diagnostic it was clicking down in the pass foot well as I tried to start the car, so I'm guessing the tech was right(see how it develops) still frustrated though, turns over fine one minute then other times does a mixture of different things, groans, clicks, splutters, now click click down by cem
louismcbillz
03-28-2017 09:05 AM
