Volvo V50 Intermittent Smoking
Old Mar 15, 2022 | 08:34 AM
Stephen Cutting's Avatar
Default Volvo V50 Intermittent Smoking
Hope someone can assist, I have a 2009 Volvo V50 2.0D which has an intermittent issue with blue smoke coming from the exhaust after a certain period of time driving the vehicle. If the vehicle is stopped and ignition turned off/ then on it goes away.
Once driving again the issue persists. The colour of the smoke is blueish (burning oil)
If anyone has had this issue or know of what to check?
NB the turbo was replaced less than 10k km ago.
Many Thanks
Stephen
Old Mar 15, 2022 | 11:50 AM
habbyguy's Avatar
Lots of possibilities (and yeah, if you shut the engine off - any engine - it'll stop smoking unless you need a fire extinguisher). ;-)
Not many folks on this forum know anything about the diesel variants, sadly (wish we had them in the US - I would probably still be driving my V50 if it was a diesel). But all the "normal suspects" are possibilities - valve seals, piston rings, PCV (if the diesel uses that), and of course, all the stuff unique to diesels (which are more prone to smoking than gas versions).
Old Nov 2, 2024 | 03:35 PM
gregac's Avatar
Default Same problem
Many Thanks
Stephen
Stephen,
I registered because of your question. I have exactly the same problem. I changed my turbo about 5k km ago... Also have smoke coming after some period of driving. Usually when I reach parking lot or waiting in a red light. Also stops after I restart a car, but continue when I continue driving. On service they still didn't find a problem after 2 visits. The car otherwise runs fine. No oil or coolant level problems ...
If you by any change found what was the problem I would be super glad for information. I'm searching for a solution almost 2 months now with no success.
Thank you,
Gregor
sj43311
Aug 12, 2017 12:19 AM
BJS
Aug 9, 2016 08:59 PM
David1984
Jan 10, 2013 05:19 AM
Max75
Apr 26, 2010 12:40 AM
joyaaron
Feb 14, 2010 10:10 AM
