01 V70 Oil Sump Seals
Old Aug 6, 2011 | 06:11 PM
zero324's Avatar
Default 01 V70 Oil Sump Seals
I was wondering if the write-ups i've found for the 98-00 V70 oil sump seal replacement would be the same for the 01 V70's.
I was going to let a local independent Volvo shop handle this task but due to limited funds at the moment i'm looking to do this job myself. So if anyone has any advice on tackling this task would be greatly appreciated.
Old Nov 22, 2011 | 10:13 AM
ALANJACKSON2011's Avatar
Default Later V70 sump removal;
Hello, did you ever find the answer to your question? I have a 2001 type 11 V70 but all the instructions seem to be for the Clasic model
Old Nov 22, 2011 | 03:29 PM
PieceKeeper's Avatar
there's a lengthy thread on the S80 forum that includes pictures. This will at least show you the scope of the job. Looks like a lot of work to get the pan removed.
Old Nov 23, 2011 | 04:55 AM
Default V70 /S80 Sump removal
Thanks for that, it looks like a struggle on some posts, while others say it is very simple. My main dealer quotes two hours (maybe he made a mistake) He is a long way away, and I do fancy doing it myself so that I can ensure it is very well cleaned. I can't work out if the 850 type V70 instructions also apply to the 2001 onwards models.
__________________________________________________ _____________
A little encouragement for those about to remove the sump on a new-style V70T. After reading all the advice and instructions for releasing the engine mounts and jacking the engine, moving power steering lines etc, I finally bit the bullet and took the sump off my new shape Y Reg 2001 V70 Turbo.
It was a doddle. I simply released the oil cooler, removed the two big bolts that go into the transmission housing, removed the fuel line bolt and all the 10mm bolts - then it just fell off !
I did forget to remove the dipstick tube, but it still came off. It is clearly more fiddly removing Classic V70 / 850 sumps.
slimflex2
Aug 7, 2012 11:39 AM
DCampion
Oct 22, 2010 10:59 AM
k1m2c3
Mar 23, 2010 04:10 PM
k1m2c3
Mar 23, 2010 07:24 AM
spunkymonky
Jan 29, 2010 09:33 PM
