04 v70 r awd only working in front wheel
Old Mar 27, 2008 | 08:19 AM
audiobiz's Avatar
Default 04 v70 r awd only working in front wheel
my 04 v70 rawd now has 115km
current issue was wondering why it wasnt having good traction in snow,, found out only front wheels spinning, no power to rear wheels at all,, no codes, no fuses blown ,, Help
Old Mar 27, 2008 | 02:45 PM
samadkins29's Avatar
Default RE: 04 v70 r awd only working in front wheel
Is the car in winter mode?
Old Mar 27, 2008 | 02:53 PM
audiobiz's Avatar
no, not in winter mode
Old Mar 27, 2008 | 03:08 PM
S70driver's Avatar
How fast were you going?
Old Mar 27, 2008 | 03:20 PM
audiobiz's Avatar
just noticed now,, as car didnt seem to have the same traction,, so backed it down hill, accelerate up no power to rear wheels just front which then end up spiinning
Old Mar 27, 2008 | 03:29 PM
S70driver's Avatar
Ok how fast were you going?
Old Mar 27, 2008 | 03:32 PM
audiobiz's Avatar
doesnt matter if i try to crawl or gas it (therefore front wheels spinning at 20, 30k, 40 on the snow) so i am presuming something must be wrong with an electronic module as car is acting as if its 2wd only
Old Mar 27, 2008 | 03:34 PM
S70driver's Avatar
Ok then. NVM
Old Mar 27, 2008 | 03:48 PM
audiobiz's Avatar
i mentioned above, first time noticed rear wheels didnt work was going up the steep hill on our driveway so below 10km, then i tested by backing down and accelerating with dtc off to spin wheels and noticed only fronts spinning
Old Mar 27, 2008 | 03:57 PM
S70driver's Avatar
ORIGINAL: audiobiz
I'm sorry to point it out to you but nowhere in the above posts have you stated you were below 10km. You stated 20, 30, 40 but never said 10.
The only one you did mention 10 in was the one I quoted.
Anyways what I was going to tell was that the AWD system on our Volvo's are not full-time AWD. After 30MPH it isn't AWD anymore it is FWD and FWD only after 30MPH. So what I was trying to get at was how fast were you going so I could tell you that.
But I can see you weren't going that fast. But it still good info to know.
Old Mar 27, 2008 | 04:06 PM
audiobiz's Avatar
my apologies, having a crazy day at work while i reply
Old Mar 27, 2008 | 08:48 PM
Bigtrev's Avatar
Ok why was everyone fighting over how fast he was going???? It doesn't matter the point is the AWD doesn't work reguardless of speed!!! Here's the deal the rear wheels are controled by a control module with temperature and pressure sensors. If one of thoses sensors gives or gets a wrong signal then it won't work properly. I'll bet there is a fault code stored in that module for a sensor issue. Also if any fluid has leaked out then it can't build up enough pressure to activate the AWD. Just take it to the dealer and they will tell you what it is.
Old Mar 27, 2008 | 09:02 PM
S70driver's Avatar
ORIGINAL: Bigtrev
Because like I said before after 30MPH there is no AWD so if he was going 30MPH+ that is why there wasn't any AWD. Thusly I asked about how fast he was going. It was a relevant question at the time and until he said otherwise it was still relevant. Now it isn't but it is still important information to know about the Volvo AWD system.
Now get back on topic.
Old Mar 28, 2008 | 12:43 PM
audiobiz's Avatar
BigTrev,, thanks fluid is low,, do you know what type of fluid to put in so i can top it up
steve
Old Mar 28, 2008 | 07:16 PM
Bigtrev's Avatar
No sorry I don't know what type of fluid it is I just tell parts I need rear differential fluid and they hook me up.
Old Apr 12, 2008 | 02:40 PM
audiobiz's Avatar
that was it ,, tnx
richardgrant
Apr 28, 2015 08:22 PM
kawish1659
1998-2000 model year V70
Feb 19, 2015 02:46 AM
Karen Cassidy
Jun 22, 2014 01:00 PM
cablejohn45
Jul 15, 2012 04:20 AM
