1998 O2 oxygen sensor replacement
Old Mar 12, 2007 | 10:53 PM
rparker's Avatar
Default 1998 O2 oxygen sensor replacement
Hi all.
I have had a 1998 V70 (non-turbo) for around 6 weeks and it is running fine. My wife phoned me at work today though to tell me the Check Engine Light was on. I got the codes pulled at a local Autozone and it showed 0172 which translates to rich mixture. The guy at Autozone said it would probably be an O2 sensor, however there appear to be 2 on the car. Since $175 a throw is quite a lot money just to see if it's that (his other option was a MAF sensor), is there a general rule as to which one fails most often? Or should I bite the bullet and replace them both anyway?
They did stock 2 parts, both Bosch, one with the full Volvo wiring loom and plug on it, the other was just 4 bare wires. The bare wires one looked to be the same part and was $99 instead of $175, is swapping the plugs over an easy option? If so, then I might just get 2 and do them both.
Once installed, do I need to get the code reset, or will it clear itself?
I should mention the car is still running just fine with the CEL on, but I guess it will fail it's smog test if I don't sort it...
Thanks for any help!
Richard
Old Mar 12, 2007 | 11:00 PM
Default RE: 1998 O2 oxygen sensor replacement
Before replacing anything check really good for Vaccum leaks.
Old Mar 14, 2007 | 12:56 AM
rparker's Avatar
Thanks Tech, you're a genius!
The fault was a perished rubber elbow that sits under the plastic cover to the left of the airbox (see pics). No idea what it does, but after it was replaced and I got the code cleared, the CEL stayed off.
You've saved me a fortune, thanks!
Richard
[IMG]local://upfiles/8650/B767248E2A7C44A88705BD397A6E8457.jpg[/IMG]
[IMG]local://upfiles/8650/80EECF68AFEE4AC8ABCD209C66545C74.jpg[/IMG]
Old Mar 25, 2008 | 02:10 PM
Daviddc114's Avatar
which hose was this? the large elbow or one of the smaller ones?
Old Nov 13, 2013 | 03:20 PM
98s70volvo's Avatar
I have a p0172 code at first it would start intermittently now it won't start at all. Help my daughter need it for College
Old Nov 13, 2013 | 04:02 PM
98s70volvo's Avatar
98 s70 with codes 0172 and 0117 changed temperature sensor and thermostat. car has rough start and idle now won't start. do i need to change O2 sensor it so which one?
Old Nov 19, 2013 | 03:50 PM
firebirdparts's Avatar
I don't think any car can no-start because of a bad O2 sensor. O2 sensors don't work at all when they're cold.
soduku007
Oct 7, 2019 04:01 PM
habbyguy
Nov 10, 2014 07:01 PM
98XCFxRUpR
Oct 4, 2010 12:37 PM
ewrench
Apr 6, 2009 05:13 PM
