1998 V70 AWD Turbo, Wastegate control solenoid hoses question
Old May 20, 2006 | 12:50 AM
tcrossley's Avatar
Default 1998 V70 AWD Turbo, Wastegate control solenoid hoses question
hello,
having purchased my car used, all of the vac lines had been previously replaced with black only hose. I have a vac hose diagram, but it's color coded so it's not much help to me at this time. I'm sure sure if mine is setup correctly. I suppose I could attach a boost gauge to see what the system is producing.
regarding the wastegate control solenoid which is clipped to the rear of the lower airbox housing, it has three connections. Let's call them TOP, BOTTOM and SIDE for explanation purposes. One goes to the TURBO compressor housing, one goes to the WASTEGATE and one goes to the fresh air intake hose.
Can someone please look at their turbo car and confirm the correct connections. (Top=??, Bottom=??, side=??) Also, what is the stock boost level of this engine?
Thanks in advance,
Todd
ENDEE666
Jan 29, 2024 01:33 PM
shawn.benson
Oct 14, 2019 10:19 AM
trackstar
Feb 6, 2015 09:07 AM
BigAl
Jul 22, 2008 06:21 PM
chance011
Aug 31, 2007 03:15 PM
