1999 V70 non-turbo 2WD transmission seal leak
Old Sep 20, 2010 | 11:56 AM
trevy's Avatar
Default 1999 V70 non-turbo 2WD transmission seal leak
I have a leak at the passenger side where the axle enters the differential/transmission.
Question 1.
Is the differential and transmission one reservoir using ATF fluid? The leak felt like gear lube, but the ATF level was a little low. Could not find a level check bolt if it is seperate.
Question 2.
How do you remove the shaft to replace the seal? Do you take off the lower ball joint and the mid axle bearing assembly, and slide the whole thing out? The mid axle bearing seems a bit loose, thinking this might be the cause of the seal leaking?
Thanks!!
danielarroyo0001
1998-2000 model year V70
Nov 3, 2014 11:26 PM
shadowfax40
May 12, 2012 11:41 AM
dwbf1
Mar 4, 2012 09:36 PM
ski351
Jun 3, 2011 10:04 AM
nighthawk
Feb 11, 2009 08:24 PM
