98 v70 acceleration sensor
Yes it would throw the code of the tank sensor is bad.
About all I can say is to try to unplug it and see if the code stops coming back.
But it might also throw the code faster.
This one is usually a pain to figure out which one is the fault.
the repair manual has a circuit test for the acc sensor, so ill try that 1st i guess. Ill have to look for the other sensors and see what happens when i unplug them. Thig is, i cant even clear the Check engine light with my scan tool. scan tool says the erasure was good, but the light never goes off. thanx for all the help, hope i can figure it out. car runs fine though also. and i have done a lot of maintenance so,
volvorecycle
Jul 22, 2015 07:44 PM
chachouu
Jun 6, 2011 08:53 PM
