98 V70 XC AWD no guts.
Hi, I am new to this forum. I recently purchased a '98 V70 XC AWD. The previous owner told me it had "a slight acceleration problem". It seemed ok on the flat road when I drove it but as soon as I tried going up any hills I noticed that it has a major lack of power. Also If I step on the gas it revs but doesn't seem to want to shift. If I drive it softly it seems to shift through the gears ok but still lacks any power.
Check engine light is on. Local autozone gave me a code for the evap sensor. ABS light is on and so is service. Almost feels like its not starting in first gear!? I can usually find answers to anything on the internet but I'm having trouble finding anyone who is reporting the same symptoms. Any ideas are appreciated. Thanks. |
Could this be the turbo?
98 v70 xc
Check level and condition of trani. fluid.( May need topping up or changing. )
Evap. problem can range from the EGR valve to a simple loose gas cap. check for leaks along the return line to the gas tank. Check abs sensor on the wheel hubs: maybe damaged or slack. On the other hand, your abs module could be faulty but could be repaired. HAVING A WELL MAINTAINED 98 V70 XC WOULD MEAN GREAT DRIVING. |
Originally Posted by Dave Yhann
(Post 394179)
