'99 V 70 sudden stalling
Old Sep 9, 2006 | 12:10 PM
dj296's Avatar
Default '99 V 70 sudden stalling
Yesterday, My '99 V 70 just stall on me on the road...and when I try to start it up, the engine on run about 1 second and just died again (as if there is no fuel pressure), after it died only 3 indicator the lighted up (the battery,oil and lambda) after 2-3 minutes, I start the engine and it runs fine and no problem although I drive more than 25 miles, at the latter time, I try to start the engine and it runs good, but at other time when I want to park my car into the garage, it stall again, and I did the same repetition and it runs well . It happened to me 2 times yesterday.
I just replace the airmass sensor and ABS module two days ago, my mechanic said that it could the the immobilizer that cause the problem,
please help
sorry if this is a repetition
Old Sep 9, 2006 | 01:22 PM
Default RE: '99 V 70 sudden stalling
Have you had the Recall software done?
It sounds like it might be a fuel pump issue.
Old Sep 12, 2006 | 06:11 AM
dj296's Avatar
Is it possible that I get the defected Airflow/mass sensor??...I change the airmass sensor because the shop recommended (The car Lambda indicator stay on that's why I brought the car in, although the engine runs normal), when it stall, the only way to make the engine runs is to stump on the gas pedal when cranking the engine
Old Sep 12, 2006 | 11:46 PM
Possible. Unplug the mass meter and start the car and see if it starts and runs better.
Old Sep 24, 2006 | 10:37 PM
V70XC1999INCT's Avatar
Wow, I have the exact same problem right now with my 99 XC wagon. I am going to try to deal with it tommorow- I wonder what this person found out?? I will post my findings when I have some. My first step seems to be a tow to the dealer (ETM upgrade info) or a reputable repair shop. Will the diagnostic check specify a fuel filter or fuel pump/ relay problem specifically?
Old Sep 25, 2006 | 12:28 AM
S70driver's Avatar
ORIGINAL: V70XC1999INCT
If your going to get the ETM software upgrade you can only get it from Volvo. Same as getting a new ETM Volvo only.
Old Sep 25, 2006 | 04:08 AM
dj296's Avatar
ORIGINAL: S70driver
on my car, it turn out to be a defected Air-mass/flow sensor (since I just replace it), the sensor hang whenever the rpm hit 2000 rpm, After I brought back the car to the shop and they run the scanner, they just change it with a new one, and the car running well ever since
Old Sep 26, 2006 | 05:52 PM
Thanks for the reply DJ- you too Tech. The dealership is replacing my ECM. They say its covered under warranty but they don't sound too happy about it. Doesn't Volvo USA pay these guys well for warranty work? HOw much was your Mass Air flow sensor? I see OEM Bosch units availible for about $120-$150. I have a strange feeling that this story is not over....we'll see.
Old Sep 26, 2006 | 05:55 PM
New ETM ...sorry for confusion.
Old Sep 28, 2006 | 12:29 AM
So they replaced the ETM under warranty. Of course they made it seem like they were doing me a favor and that they were not required to replace the faulty unit. Conveniently the Mass Air Flow sensor was also bad and that's not covered under warranty. I can buy a bosch unit online for $120. At the dealer the cost is $230 and of course an extra $150 to install it even though it's right next to the ETM unit. I was told the extra cost covered the "extra diagnostic and road testing" as well as labor. What a Crock! I hate getting service at these dealerships- not just Volvo. I have a friend who is a mechanic and he sometines bills 150+ hrs a week in labor charges. of course he only works 45 hrs. a week. Granted he is a good mechanic but what a scam for people to pay so much more that the real cost for labor- not to mention marking up the parts 200%. OK my little rant is done..sometimes you just have to get this stuff off your chest. Oh- and as I left the lot the Service lite came on again[:@]
Old Sep 29, 2006 | 09:10 PM
If you are under 8 Years 80,000 miles call Volvo Cars and talk to them some emmissions parts are covered to the 8-80,000 miles.
Did they do an oil change on the car?
Did they forget to reset the light?
Old Sep 29, 2006 | 09:34 PM
No, they did not do an oil change. why do you ask? The service "consultant" said that they reset the light. Luckily I live in area where there are about 5 volvo dealerships within a 25 mile radius. In fact I called another dealership while I was waiting for 2 days to have them read the codes and they were appalled at the "slow" service.
Old Sep 29, 2006 | 10:21 PM
Wow ok.
Just wanted to make sure they reset it. If they did an oil change and it came back on then I would say their fault.
But also keep in mind I have had that happen to me as well. I would reset the light go on a test drive come back and shut the car off and restart again and the light is on again.
Unless you mean engine light?
volvoinct
Jun 8, 2022 03:30 PM
volvo_s70
Aug 28, 2009 10:12 AM
dex_sinister
Jul 11, 2007 03:03 AM
soapboxhero
Jan 6, 2007 11:56 AM
dcox612
Nov 10, 2005 01:06 PM
