99 V70 Check engine light
Old Sep 11, 2005 | 05:47 PM
dane's Avatar
Default 99 V70 Check engine light
I'd appreciate some help on this issue before I take it in for a diagnostic. I live in a hot climate and I just got the dreaded check engine light on.
Any suggestions?
Old Sep 11, 2005 | 06:05 PM
Default RE: 99 V70 Check engine light
The only thing I can really suggest is to make sure the gas cap is on all the way.
Stop by your local Auto Zone and have them pull the codes.
Old Sep 11, 2005 | 09:33 PM
dane's Avatar
thanks...
I'll let you know what happens
Old Sep 11, 2005 | 09:37 PM
Ok cool.
Old Sep 12, 2005 | 07:33 PM
dane's Avatar
OK
Looks like the Auto-Zone is a good place to get a diagnostic (free is good). Turns out the code was P0172 and I was told that it was due to a faulty fuel/air ratio. So maybe that means too much gas and too little air or any thoughts?
Old Sep 12, 2005 | 08:53 PM
Could be a massflow sensor going bad,A coolant temp sensor going bad,or a vaccum leak.
Old Sep 17, 2005 | 02:07 PM
dane's Avatar
Volvo pulled the codes and said that it indicated a misfire, fuel trim level was off, and air flow sensor issue. But when they went to check it out, they found nothing wrong with either. We purchased the car used with 67K and the dealer washed the engine before they put it on the lot, so the mechanic said that this sometimes causes temporary problems. They cleared the CEL and said the car drives fine. Should we pursue this further since its under warranty or take it home and see what happens?
Thanks
Old Sep 17, 2005 | 05:30 PM
Drive it and see what happens.
That is true if the engine is washed with water it will cause it to missfire.
tngreg
Sep 5, 2022 07:27 PM
ErnstlS90
Oct 23, 2008 08:37 AM
mstrplmber
Aug 28, 2008 03:34 PM
BRB
Feb 9, 2008 12:29 AM
llama_of_doom
Aug 23, 2007 09:52 PM
