99 V70X/C AWD idles like crap
Hi folks,
I normally frequent another forum (for ford trucks) and I do pretty much all my own repairs. My girlfriend's father will be staying with us for a few weeks and he brought with him a lemon of a 1999 V70 wagon that has more things wrong with it than right. It's an automatic with the inline 5 turbo engine.
Nevertheless, I would like to fix the problems with this car and get it running decent. It currently has NV tags on it, and it will need to pass CA emissions, and I'm pretty sure it won't the way it runs now.
The history of the car - he bought it from a small dealer lot in Reno. They told him they would stand behind the car, and they have done their part so far. It has had the entire top end of the motor rebuilt after the timing belt slipped and then broke. I haven't seen the invoice, but supposedly they machined the head and did a valve job. I can't believe they let it out of their shop running like this, but they did. Their story is that they couldn't figure out what's wrong with it. Fantastic.
First problem - it idles like a WWII tank. It's so rough it barely idles. When it's cold, it will stall the first couple times you start it. After it warms up it will still idle like crap, but won't actually stall. On the highway, it runs better, but not nearly as smooth as it should. Even when the motor is at full temp it idles like crap. None of the diagnostic lights are lit.
I've searched on here, and it seems that a dirty throttle body, a dirty MAF sensor, or a bad O2 sensor could be the cause. I haven't torn into it yet, but those are the first things I'll look at. Anything else I'm missing? In the event that I have to buy parts for this, where do you recommend that I get them? I'm a big fan of buying auto parts online from reputable places, mainly because they're a lot cheaper and of better quality than the junk autozone sells.
Any tips for cleaning the MAF sensor? Or the TB?
Second problem is that the steering makes an awful clunking noise when you turn it in either direction. This feels like CV axles to me. I've replaced CV axles on small cars before - how hard are these to change on this car?
Thanks for any help - this seems like a very helpful forum.
RE: 99 V70X/C AWD idles like crap
Do the turbos have an idle control valve like the non-turbos (I ask this because BMW deleted Idle Control Valves when it went to electronic throttle bodies, but apparently Volvo did not)? I thoroughly cleaned my V70's ICV last weekend and it solved all my problems related to erratic idle. Too low or erratic idle could contribute to the roughness, and if the ICV is open too far during normal operation, it could probably screw up air/fuel metering.
I have a '99 with the electronic throttle body. If not an idle control valve, what valve did I clean that was attached to the main air duct just downstream from the mass airflow sensor? It was pretty gunked up with carbon and the car definitely idled better afterwards. Of course I did a little bit of swabbing on the throttle body, but not enough to make the kind of difference I am experiencing.
I thought it was strange that the air hose seemed to go close to the injectors. If it's not exposed to the intake manifold, I wonder how it got so gunked up with carbon. And why cleaning the valve had a significant impact on my idle. Maybe it was the minor cleaning I gave to the outward facing side of the throttle body, but I really did a substandard job there, so I doubt it.
