AC Will Not Turn On
AC Will Not Turn On
I know there are several threads on AC, and I've probably looked at them all by now.
Here's where I'm at:
Replaced accumulator, evac'd/recharged system, worked great for my 1hr drive back home.
Got home and noticed a teeni leak at the LP sensor, went it to get a wrench, by the time I got back out, the AC had stopped running.
From the forums and offline advice from Tech, I have replaced, one at a time, the high pressure sensor, blower motor resistor and compressor relay.
Some observations:
Compressor will come on and make nice cold air when jumpering the relay.
Engine cooling fan does not come on when AC button is depressed.
The low pressure switch is OK.
13v on both sides of relay coil (the control lines to the relay)
Tried multiple HP switches in case 1st used one was bad
I know it's a pain, but does anyone know how to bypass the high pressure switch?
Anything I've missed?
Thanks,
Chris
Some observations:
Thanks,
Chris
Me too
I have not checked to see if there is too much pressure yet, but doubt it seeing that it worked so well for the ride home.
Tonight I noticed that when I forced the it on for a minute, seemed like the high side/orifice tube got hot. Can't really tell if it was hot from the temp of the engine or from use of the AC.
I'll make an appt with my local Volvo professional and report back.
Are there any inexpensive scan tools or programs that will do the Volvo specific codes?
Chris
Chris
Shop said there was a code in the system for the LP sensor and that was causing it not to come on. Would an existing code cause the system not to work at all? Does the code really need to be cleared to turn it on? They said the code probably ocurred because I removed the connector while the engine was running...makes sense. They ran it for a while and then said it shut off after a bit because of a bad AC clutch. They want $300 for the clutch + labor, they would not reshim it for me.
Since I have no way to clear AC codes, guess I should disconnect the battery to reset them in the future...will that do it?
Chris
Chris
Yeah, theyporked me pretty good. $120 to clear the code, to turn the compressor back on to tell me something I would have been able to figure out if the the code wasn't keeping the compressor off in the first place
Quoted $428 for the clutch with labor.
They wouldn't even reset my service reminder light for free...gimme a break.
Tech, what's your take on the "bread-clip" shim method? Does your shop do reshimming or just install a new clutch. Seems like they only last around 80k before needing the shims.
Chris
Chris
So assuming that the clutch is either bad or needs to be reshimmed, tonite I tried the two things. First I pushed on the outside of the clutch with a wooden stick, it did not re-engage. I then measured the power line going to the clutch. Power on that line cycles with the engaging and disengaging. If I jumper the relay the clutch will engage. It seems to me that something is telling the AC not to come on.
AC works great when you first start the car or on the highway. Once the car is warmed, or you get off the highway and hit traffic lights, the AC cycles and eventually stops cycling and does not come on at all.
Would you agree that the clutch is most likely not the problem? I'm going to end up bringing it back to the mechanics and making them look at it again at no charge.
Chris
Chris
