Air guide and fog lights
Old Nov 14, 2008 | 08:40 AM
rmendoza's Avatar
Default Air guide and fog lights
Hey there,
I found a set of fog lights and the air guide from a 99 xc70. Will these fit my 98 v70? If so, what do I need to do to install the fog lights, besides mounting them of course? Is there a a lot of messing around with the wiring? Thanks a lot for your help.
Old Nov 14, 2008 | 09:48 PM
rmendoza's Avatar
Default RE: Air guide and fog lights
Bump! Anyone?
Thanks.
Old Nov 14, 2008 | 10:31 PM
TIPSP's Avatar
Got Boost?
Not sure if it will fit..you can always test it.
I thinkthe carmight be pre-wired for the lights...not 100% sure on that though.
Old Nov 15, 2008 | 01:07 AM
rmendoza's Avatar
Thanks for your response. It seems like the lights might fit, but you would need the little grilles that go right next to the lights themselves. In any event, I found the following document, which depicts (literally) the installation of the fog lights:
http://volvospeed.com/vs_forum/index...e=post&id=3741
Maybe someone else will find a use for it. Thanks.
Old Nov 15, 2008 | 09:30 AM
Yes they should fit fine and like stated you will need the new shorter grills.
rspi
Jan 13, 2012 09:35 PM
aprilair123
Sep 3, 2011 10:19 AM
ddorshimer
Sep 5, 2010 02:37 AM
Yola
Oct 29, 2007 08:08 PM
